In Studio 9 I could choose how long the software should capture before it stopped creating the avi file. Since I run analog video through a DV cam I need to be able to choose the time before I start capture, if not Premiere Elements just keep capturing till the HD is full or I click stop. When I start a 1,5 hr tape I want to be able to choose that after 1,5 hr it should stop capturing. If I start this when I go to work it will capture till I get home 9 hrs later. Does anyone now how to choose how long Premiere Elements should capture before it stops?
Results 1 to 1 of 1
Specific Monitor/Dtv set top box problem
By lg1 in forum DVB / IPTVReplies: 6Last Post: 22nd Apr 2012, 17:57 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
Adobe Premiere Elements 2.0 and 4.0 installed at the same time
By Mållgan in forum Capturing and VCRReplies: 0Last Post: 26th Aug 2009, 01:21 -
Premiere Elements 4 HELP!
By tczerwinski in forum EditingReplies: 3Last Post: 28th May 2008, 08:55 -
Premiere Elements 3.0
By sm head in forum Capturing and VCRReplies: 2Last Post: 28th Jun 2007, 14:42
