Hi, I just recieved several .avi files that I need to review for a project, and I read that ffmpegx can convert these formats to something viewable by quicktime or vlc... However, when I try to open this file up in ffmpegx, it says it's 'unrecognized' in the "from" field. If I click on info, then it says: video [FPS1] 800x600 24bpp 30.000 fps 78722.6kbps (9609.7 kbyte/s)
After trying to convert this file regardless, I get:
Encoding started on Sat Oct 28 01:27:59 PDT 2006
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x119de960
AVI: invalid audio stream ID: 1 - ignoring (nosound)
AVI file format detected.
AVI_NI: No audio stream found -> no sound.
VIDEO: [FPS1] 800x600 24bpp 30.000 fps 78722.6 kbps (9609.7 kbyte/s)
[V] filefmt:3 fourcc:0x31535046 size:800x600 fps:30.00 ftime:=0.0333
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=272]
Requested video codec family [fraps] (vfm=vfw) not available.
Enable it at compilation.
Read DOCS/HTML/en/codecs.html!
Cannot find codec matching selected -vo and video format 0x31535046.
Exiting...
Anyway, I am not sure what DOCS/HTML/en/codecs.html is referring to... And I am further unsure how to enable it at compilation, especially since I believe I downloaded a precompiled version.
Can anyone help me?
-patrick
From the ffmpeg website: "FFmpeg has a Fraps FPS1 video decoder. This video codec has 3 different versions and this new decoder supports the first 2 versions so far."
- Try a --ffmpeg preset; do not decode with QT.
- If you have the one version of FPS1 that ffmpeg cannot decode, you may be out of luck with this tool.
- Mencoder/mplayer doesn't have native FPS1 decoding (yet), don't use this combo for decoding on Mac OS.
Trouble With FRAPS
By Auroraah in forum Capturing and VCRReplies: 0Last Post: 21st Jan 2012, 13:48 -
Fraps Fraps Fraps !!!!
By oOParaOo in forum ffmpegX general discussionReplies: 3Last Post: 30th Jun 2011, 18:02 -
fraps
By krohm in forum Capturing and VCRReplies: 16Last Post: 30th May 2011, 21:43 -
FRAPS lagging!!!
By LoveMyslf in forum Video Streaming DownloadingReplies: 7Last Post: 8th Nov 2008, 15:35 -
Fraps on MAC
By Smoogle in forum ffmpegX general discussionReplies: 2Last Post: 4th May 2007, 23:40
