Results 1 to 10 of 10
  1. Member LSchafroth's Avatar
    Dec 2002
    I downloaded Vegas 7 to play around with. I installed WAX 2.0e.
    It's documentation states there will be a WAX Video FX and a WAX Transions filter listed in Vegas. The only thing listed is WAS Plugin1, through 5. No description of what they are.
    I was able to fumble around and get a virtualdub filter loaded, but cannot find anywhere to change the options for the filter.
    It's most likely my newbieness on Vegas. Can someone help me?
    Thanks!
    LS
  2. Member LSchafroth's Avatar
    Dec 2002
    Got wax in your ears???
    Hello?
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
  4. Member LSchafroth's Avatar
    Dec 2002
    OK, so I had Wax in my eyes!
    That's what I needed. Works. The only drawback is I cannot see the preview while in WAX. I have to use the HOST MEDIA dummy option for it to work.
    All I see in the preview window is the HOST MEDIA graphic and how the filter would change it. So I have to make a change and exit out of wax and preview in Vegas. Then go back in and out until the changes are to my liking.
    But hey, it's working so I can learn!
    Thanks!
    LS
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    for preview - i forget exactly , but it is something like turn off completely memory for preview .. it is in the vegas options (preview buffer)
  6. Member LSchafroth's Avatar
    Dec 2002
    I have both Vegas preview at 0 and WAX at 0. All I get is the dummy media.
    LS
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    the exact instructions are on the sony vegas forum and in the knowledgebase .......
  8. Member LSchafroth's Avatar
    Dec 2002
    If its so availble where is the link?
    I'll see if I can find it. I went there once and didn't find anything but I'll try again.
    LS
  9. Member LSchafroth's Avatar
    Dec 2002
    I can't find anything in Sony's knowledge base or in their forums.
    I found a few talking about setting the preview window to 0.
    I have it on 0 in WAX and Vegas. If I uncheck the use dummy media then when I use WAX I get a PLEASE WAIT... after loading the filter.
    It sits there forever.
    LS
  10. Member LSchafroth's Avatar
    Dec 2002
    I turned off the dummy setting and after 5 minutes of seeing PLEASE WAIT, it says "Unable to determine event length. Please check if you can run scripts"
    I searched Sony's knowledge base and forums with no luck on that phrase either.
    LS
