I've used a few programs converting AVI's to DVD's so i can watch them on my DVD player.
What do you guys think is the best converter ?
One that does the best job and does it at a reasonable speed.
Thanks in Advance
SUPER
http://www.erightsoft.com
By far the easiest and cheapest (FREE!) "all-in-one" solution out there. Best of all it gives you the choice to use not one but TWO encoding engines for encoding to DVD specs; FFMPEG (my choice) or Mencoder. The GUI has a good amount of options for minimal tweaking and even accepts AviSynth scripts! If you give it a try you'll soon discover it's rich potential.
A real no-brainer. -
What kind of AVIs? What does "Best Job" mean? What do you consider a reasonable speed?
I generally work with DV-AVI and I use QuEnc to encode to DVD compliant Mpeg2 video and AC3 audio. I then author in TDA. Encoding usually runs at about 12-15 fps and authoring usually takes about 15 minutes. I find this method gives me what I consider excellent quality in a reasonable amount of time."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
The simplest solution providing the best quality in most cases is to get a stand alone player that is Divx certified. Just burn to DVD as data and play. No conversion, no quality loss.
The next best method, for my money, is FitCD, avisynth, ProCoder (or ProCoder express or CCE Basic or HCenc) and DLP. Add some filters to add back detail and blend the blocking artifacts that all Xvid/Divx files suffer from, and you will get the best possible solution. The cost for this method is time. It may take 3 - 5 hows computing time per movie.
Simple one-click wonder solution at a cost is ConvertXtoDVD. I like this over some of the free and all of the commercial one-click solutions because it is fast, and because it correctly encodes 23.976 material as 23.976 with pulldown, not 29.97 as many others do.Read my blog here.
tool to extract clip from a dvd to avi
By syeager in forum DVD RippingReplies: 2Last Post: 5th Apr 2009, 11:54 -
a good tool for converting avi or divx to the dvd vob format?
By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 14:37 -
Your favorite DVD-to-AVI tool?
By shira in forum DVD RippingReplies: 3Last Post: 26th Jan 2008, 13:41 -
Best tool for DV AVI -> DVD?
By timmus in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2007, 12:58 -
free tool for avi to dvd
By bmw2007 in forum Video ConversionReplies: 5Last Post: 29th May 2007, 17:30
