Anyone know whether Nero can produce data DVDs (containing HTML, PDFs) that can be read by PCs and Macs?
Regards,
Ian Tresman
Absolutely. But if you're still unsure, try a test CD-RW/DVD-RW, and write a normal data disc.
If cameras add ten pounds, why would people want to eat them? -
That was quick!
Any idea which DVD format I should choose to be PC/MAC compatible? DVD-ROM (ISO), DVD-ROM (UDF), DVD-ROM (UDF/ISO)
Regards,
Ian Tresman -
As DVD's are "supposed" to always be premastered using (at least) the UDF filesystem, which is natively supported by Win98SE and higher, and by MacOS8.5 and higher. That should do the trick. Now, if you want the Macs to also see their usual ResourceFork stuff, you'd want to make a Hybrid (aka Bridge) disc. This can be done in Toast on the Mac, and with much more difficulty using a combination of tools (incl. Macdisk/MacImage) on the PC.
edit: To clarify--always use UDF or UDF/ISO (or maybe UDF/ISO/Joliet/HFS
Thanks for that. I know nothing about Macs. Is it any real disadvantage if a Mac user does not see their "ResourceFork stuff"
Regards,
Ian Tresman -
Depends.
OSX has changed that somewhat, to make macs less dependent upon that stuff. Much more like Unix and WinPC's--file extensions, only data forks, etc.
Older macs REQUIRE them, not just for correct file associations, but lots of stuff might reside in the resource fork.
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2378Last Post: 27th Nov 2025, 10:38 -
Hybrid on mac,..
By Selur in forum MacReplies: 72Last Post: 7th May 2012, 01:47 -
Will A DVD Data Disc Work On Mac As Well As PC?
By blazin-j in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2010, 10:52 -
MAC vs. PC Video Data
By kevin.handley in forum EditingReplies: 7Last Post: 1st Jan 2009, 14:55 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 17:00
