I downloaded and installed huffyuv codec but I haven't used it yet on a 24 min video.
Please tell me the outcome size of the video because I'm not sure how many gb this file will occupy. My hard disk is 80 GB and Free space is 35 GB.![]()
take life for granted
you should really get a second large hard drive.
you may very well run into sync. issues capturing to your system drive, especially when you're cutting it so close.
remember you're also probably going to want to edit/render to another format. So then you'll be reading/rendering/writing to the same almost full hard drive.
DVD Recorder vs Huffyuv Uncompressed
By jrodefeld in forum Capturing and VCRReplies: 23Last Post: 11th Jul 2011, 10:22 -
How do I save uncompressed video fast
By crankyslap in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2010, 18:14 -
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 09:11 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
How to convert uncompressed video to lossless HD
By Freeloader in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2010, 12:59
