  1. I'm Ripping DVDs on SmartRipper successfully only with the Audio Commentary on!How do I turn it off?
    May 2001
    Eric
    All the audio tracks are included with the VOB files. In this case the default track has the commentary. Assuming you are going to encode this for VCD, then when you convert using DVD2AVI, select another track in the audio. You may have to do a couple of short tests to get the right one.
