So for some time i had an LG DVDRW using Smartbuy Media (ProDisc F01 - Metallic orange). After some burns i found alot of burns with crc errors. So from there i bought some Benq Media (DAXON008S).
After some 2 good burns, an error popped up and writing failed. From there i changed DVDRW to a NEC3550A one. Again used a Smartbuy and 2 Benq media and they went fine. When i used another Benq with DVD Decrypter, i found a Power Calibration Error in DVD Decrypter log. Scrapped that single media and tried another, this time it started writing with a slow speed for a few seconds until an error (i Think same as the one with LG) popped up again.
Error on NEC:
Now, i need some help on what to do, i tried new media and a new drive to no avail :S
Help please
Regards
Try using ImgBurn 2.1.0.0, its a newer version of the same burn engine in DVDDecrypter. Make sure all your drives are in DMA mode. It usually is best to have the latest firmware in your drive also.
DfraGG3r,
It looks like the drive doesn't like the media. To verify that, it would help if you would post a burn log. If you don't have one, you can make a "Test Mode" burn to get a log without really burning to the disk, so the disk will still be useable in the future. Just keep in mind that "Test Mode" only works with -R media. With +R media, it actually burns to the disk.
It would also be a good idea to follow GKar's recommendation to upgrade to ImgBurn for your burning. It's also freeware, by the same author that gave us DvdDecrypter.
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 21:47 -
Sony capture probs
By DaveDLF in forum Capturing and VCRReplies: 13Last Post: 23rd Mar 2009, 21:20 -
A few probs with FAVC
By kronick in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 20:25 -
sync probs with dvdx
By zookeeper525 in forum AudioReplies: 0Last Post: 18th Aug 2007, 23:28 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 21:29
