    Aug 2005
    Outworld
    High, I have authored a dvd containing about 5 clips, 40 mins or so each.
    In connections layout I have link them all in order, so that one will play after the other. I have also changed "UOPS and settings" for each clip to make it possible skiping forth and back using "next" and "prev" buttons on the remote. This however unticked "adhere to DVD 3- 4.3.2".
    There's also a created menu to jump to a specific clip.
    The skipping stuff works OK on domestic player, however if I press FF (fast forwarding) it advances a little bit and then skips to the next clip and plays.
    Why this happens?
    Apr 2004
    Miskatonic U
    What did you use to encode the mpegs ?
    Read my blog here.
    Aug 2005
    Outworld
    CCE SP2
