Is it possible to create a script to extract the audio stream as an uncompressed WAV file in VirtualDub?
What is the audio type that you will be extracting?Originally Posted by Andrex
For instance if the original audio is AC-3 then you con't want to extract as a WAV file. If the original audio is MP3 then again you don't want to extract as a WAV file at least not with VirtualDub.
Use VirtualDub (I use VirtualDubMod) to DEMUX audio when it is AC-3 format.
If the audio is MP3 then load the AVI into GOLDWAVE and save it as a WAV file.
If you're not adverse to writing batch files, you can try the command-line version of AVI2WAV (which should be included in the main AVI2WAV archive). I don't know how it fares with AC3 audio in an AVI, though... and yes, it should probably be extracted rather than converted to a WAVE file in that case.
I think AVIDemux may also be able to demux streams from AVIs, but I haven't tried it, so I don't know if it supports batch demuxing.
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
Saving multiple AVIs from 1 AVI by virtualdub script
By DveD in forum EditingReplies: 1Last Post: 16th Oct 2009, 08:47 -
Simple DirectShow script for virtualdub
By streamking in forum Video ConversionReplies: 2Last Post: 28th Jan 2009, 14:43 -
VirtualDub problem - error during script execution
By ineedhelp123 in forum Video ConversionReplies: 17Last Post: 31st May 2008, 07:29 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 19:03
