Hello All
I'm a newbie to video conversion and presently use Total Video Converter 3.0 trying to convert Flv to Xvid. And for some reason the conversion fails the video but the audio is ok.
I also installed Xvid from free codec.com, however when I convert Flv to Divx it converts both video and audio ok...
What is the difference between Xvid and Divx ??
I have Direct x 9.0c on my system
Thanks..![]()
You might take a look here: https://forum.videohelp.com/viewtopic.php?t=304962 Especially near the bottom of that page and that might help your video conversion problem.
EDIT: Sorry, that was for FLV TO DVD. This one is for FLV to Xvid or Divx: http://www.digital-digest.com/articles/FLV_to_AVI_Conversion_Guide_page1.html
DIVX: https://www.videohelp.com/glossary?D#DivX
XVID: https://www.videohelp.com/glossary?X#XviD
They are very similar. I actually prefer Xvid. Others can explain the exact differences.
And welcome to our forums.
Thanks for the Info...
I had to Uninstall Total Video Converter 3.0 because when I attempted to play the Xvid on the WMP or Real player I would get the BSOD and a reboot.
The TVC needs a software update to fix the Xvid converter problem...
FLV conversion...
By mjl1297 in forum Video ConversionReplies: 11Last Post: 11th Apr 2011, 10:48 -
.flv to DiVx/XVid
By laserbeak in forum Video ConversionReplies: 9Last Post: 26th Aug 2008, 10:58 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
flv > mov conversion fails, empty file, why?
By sduck409 in forum ffmpegX general discussionReplies: 2Last Post: 5th Feb 2008, 22:04 -
Video not working after x264(MKV) to Divx/Xvid(AVI) conversion using TVC
By CthulhuSaves in forum Video ConversionReplies: 7Last Post: 3rd Jan 2008, 23:12
