Could someone tell me please what DVD authoring tool is the best for audio sync issues?
I am using Nero Showtime to burn but the audio is out of sync when I burn it to DVD.
However it is OK when I play the movie on the pc?
I looked through the "Tools" section and read the reviews for some of the DVD Authoring tools but couldn't decide which one is best.
Just authoring doesn't usually cause any sync problems...it's the converting to dvd mpeg2 and especially from downloaded sources. If you want all-in-one converting and authoring solution try ConvertXtoDVD.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
