I am in the process of uploading a hord of mini DV tapes to PC. I do not have the time to sit there when the video ends after 30 minutes on a 65 tape. So I end up with 35 minutes worthless data taking hard drive space after the video completes. Can I resave the original AVI file as another AVI file with the last 35 minutes edited off, or will that process diminish video quality?
Thanks for any insight J
Use Virtualdub and cut the last 35 minutes out.
He's a liar and a murderer, and I say that with all due respect. -
Don't forget setting direct stream copy mode for both video and audio in VirtualDub and save as old format. You'll keep the input quality.
You don't specify what system you have, but if you have XP, you can use Windows Movie Maker....it's part of XP.
John Miller
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
