Hello everybody,
this is my "First Contact" with this wonderful forum.
Hope i can get some help with my "quicktime-questions".
I already tried to find help with the search function but had no luck. Most of the Quicktime related question are about conversion to or from quicktime.
Actually i need help with recompressing Quicktime movies.
First question would be if there is some tool similar to Virtualbub where i could set only the video track to be recompressed but keep the audio track untouched. Just like the "direct stream" option in Virtualdub.
Reason is that i need to make some quicktime movies smaller but have to keep my hands away from the audio track.
Second question would be about recompressing quicktime movies.
It seeems that either i am to dumb to get it done or quicktime is not very good in that field.
My problem is that i can't set "Quicktime Pro" to recompress my files at a given data rate.
Here is an example:
Let's say i got a movie that is 1 GB big which i need to make 20 % smaller.
Let's presume that the movie is compressed originally at 4000 kBits /s. So to make it 20% smaller i enter 3200 kBit/s (which would be 80% of the original kbit/s) into the "limit data rate" window hoping this will reduce my file to 80%.
But this does not happen.
After exporting the fiel is still apprx. 1 GB huge. So i go lower with the data rate but filesize still remains almost as huge as before.
Then i reduce data rat even lower, maybe at 50%, hoping that this might reduce the filesize at least close to the aimed size.
But now the file becomes very much smaller than needed.
This is driving me nuts.
Setting a certain filesize and data rate seems to be a total matter of guess and try.
What am i doing wrong?
doing the same task in DIVX is so much easier. Here you set your desired data rate and all works fine.
Why is it so terribly unpredictable in Quicktime?
What video codec are you using? Cause quicktime mov is a container. Or maybe it's not possible to select codec with quicktime pro, was a long long long long long time ago I used it.
Help desperately needed with HDD problem
By jeanpave in forum ComputerReplies: 28Last Post: 17th Jul 2011, 23:41 -
Problems importing Quicktime movies into Sony Vegas
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:31 -
Error 2048 Quicktime Problem (Home Movies)
By cliffm10 in forum Software PlayingReplies: 0Last Post: 19th Apr 2010, 12:06 -
Joining Image and Two Separate QuickTime Movies
By lindylex in forum EditingReplies: 2Last Post: 13th Mar 2008, 13:30 -
any quicktime movies go green
By matneaves in forum Software PlayingReplies: 4Last Post: 5th Aug 2007, 16:00
