Is there a metod to recover data from a non-working cell phone without buying a new battery? My battery went dead and I don't really want to buy a new one, since I have to get a new phone anyway. I got some phone numbers that I'd like to save.
Results 1 to 20 of 20
moved to another forum, nobody likes me here...
CSI and NCIS can do it...
Sorry...
Can you turn it on while the charger is plugged in? -
you can just transfer the sim card to a working phone .... all the data will be on it ,,,,,
if the battery is completely zonked then a charger won't be any good as chnaces are it still needs the battery to make the circuit. Mmaybe you could short out the battery connection in the phone as a last resort
as for the sim, sometimes the data is saved only the phone and not to the sim depending on how you save your numbers
you could also think about using another similar spec battery and jumping the connections with wires so you can save all the data to the sim
if you are desperate and cannot get it to work then call into some local phone shops and ask the guys if they have a test/old battery they could try. Some may charge you a few £'s or some may even do it free and others will try and sell you a battery
I have lost numbers years ago when I lost my phone but I managed to get a few back using my itemised bill
What is "the sim card"
Do I have to take the phone apart to get to it? Only removable part is the battery...
I can turn it on, but it cuts off after 20 seconds and I'm not able to access menu in 20 sec.
I saw a battery on ebay for this phone very cheap, anywhere from $10-15 including s/h.moved to another forum, nobody likes me here... -
Have you tried to take it back to the Service provider and see if they can move the data from one phone to another?
sim card is a chip you can remove without tools - its under the battery or might be under the battery compartment shield
Yes, and they said that phone is too old and they can't do nothing.Originally Posted by Bodyslidemoved to another forum, nobody likes me here...
I don't see the chip in this phone that would be removable without any tools,,, it must be inside.Originally Posted by BJ_Mmoved to another forum, nobody likes me here...
that's what you get when you buy the Lego phone from the 70's!
what kind of phone it and how old is it?
If you really want the numbers and want to take the safe route I'd be looking at Ebay for the $10-15 you said. The quick and daft way (which I'd try as I'm like that) would be using the charger somehow to fire it up
in that case - it doesnt have a sim cardOriginally Posted by fLYtRap"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Here is the link to an ebay auction for some accessories for this phone:
http://cgi.ebay.com/Lithium-Battery-6-items-for-Samsung-SCH-8500_W0QQitemZ120046434372...QQcmdZViewItem
...and here is the battery, which I'll get if there is no other way:
http://cgi.ebay.com/Samsung-SCH-8500-850-811-OEM-Lithium-CELL-PHONE-Battery_W0QQitemZ2...QQcmdZViewItemmoved to another forum, nobody likes me here... -
Hey, can I just wire a couple of 1.5v home batteries???
Thats exaclly what I did...
so do you mean you have done it with batteries or are you asking?
I did it with 3 batteries from my stereo remote controllersOriginally Posted by MackemX
I hooked a couple of wires to batteries and the phone and that worked just fine. I got all the numbers saved 8)
I have a similar problem...My cell phone display went out.
I bought a new phone and would like to transfer contact numbers from the old one to the new one. I know that I probably can get the cell provider to do it but wonder if I can do it myself?
What software/hardware do I need? Can it be done if the display is out? Do I transfer to computer hard drive then to another phone? Is there a tutorial on this subject?
thanks for your help. -
what phone is it that is broken?
if you have a destruction manual for your phone you may be able to do it blind. If not can you get hold of a same model phone as then you can see what you have to press. If not do you know anyone who has a similar phone (a mobile phone shop) who could help you? Or you could ask on this forum for some help as it's pretty big
http://www.howardforums.com/
if you can do it somehow then you'd need to transfer all your numbers to your sim card (this may be in the instruction manual) and then you simply put that sim in a new phone -
this is a old phone
(from capmaster's house)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Do you use a cell phone?
By johns0 in forum PollsReplies: 12Last Post: 23rd Jan 2012, 23:39 -
Upload games to cell phone
By BLSAMPLES in forum Off topicReplies: 9Last Post: 30th Aug 2009, 21:39 -
Ring Tones on cell phone
By BLSAMPLES in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2009, 21:49 -
dvd to cell phone
By molinman in forum Video ConversionReplies: 2Last Post: 4th Jan 2009, 12:25 -
Ripping MP3 from Cell Phone
By Vance in forum AudioReplies: 0Last Post: 21st Jul 2008, 14:34
