1)Reason:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
2)Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
SPAM team
You are in breach of the forum rules and are being banned for spamming.
/ Moderator mats.hogberg
Aside from the fact you are banned...this post makes no sense.
Google is your Friend -
Very Informative!!!
So, I have a battery pack, 9.6 VDC @ 900 mAH - it's an 8 NiCAD cell pack wired n series - each cell 1.2 VDC/Cell At 900 mAh.
According to your formula (Activate the battery and current 1.5 time higher then the highest ones of battery).
1.2 VDC x 1.5 = 1.8 VDC
900 mAH x 1.5 = 1.35 Amps
So, I should charge this sucker at 1.8 VDC @ 1.35 amps.
You sir, are a ******* genious!
I have a strange problem and I would like to ask if is possible to be solve
By takis76 in forum SubtitleReplies: 1Last Post: 8th Dec 2010, 14:53 -
How do I solve this file joining problem?
By A_Shepherd in forum EditingReplies: 30Last Post: 2nd Sep 2010, 13:27 -
Can you solve my choppy video problem?
By imrealdumb in forum Newbie / General discussionsReplies: 2Last Post: 4th Jun 2009, 20:44 -
Unable to solve a boot problem, really need some HELP.
By blinky88 in forum ComputerReplies: 5Last Post: 24th Apr 2009, 16:17 -
Bad battery or mobo problem?
By bevills1 in forum ComputerReplies: 8Last Post: 19th Jun 2007, 11:51
