I have some high quality VOB files. I need to convert them to a different file type because Vegas 5 doesn't seem to be able to read them. Along with mpg2. I tried the VOB2MPG2 program but Vegas 5 wouldn't read it. So i'm assuming the program was not doing it's job right..or Vegas 5 doesn't read mpg2. So I need a program that will convert the files to another format (preferably high quality). I really need these files to be high quality. It's essential. Please introduce me to a program that will do this. If you are familiar with Vegas 5, please give me a program that is compatible with it. If not, it would still be helpful to try out any programs. Thankyou once again.
A few things to try:
1- Have you renamed the .vob ext to .mpg? That works for me sometimes as Vegas doesnt import vob files directly.
I dont understand when you say Vegas 5 also doesnt read MPEG2 files as it most certainly does.
2 - If you need another program try virtualdubmod to import the vob files and then save them as DV AVI or uncompressed AVI (huge file size). Then import into vegas and do your stuff.
Virtualdubmod is freeware. -
your file should say whateveritscalled.vob - right click on the file and click rename from the options and change the .vob to .mpg
Renaming a VOB does not give you an mpeg, just file with an mpeg extension. VOBs may also contain; multiple video streams, multiple audio streams, subtitle and subpicture streams, menus.
Vegas 6 and 7 will accept VOB files, however the support is designed for VOBs created by DVD based cameras, not commercial DVDs.Read my blog here.
high quality mpeg-2 encoding
By deadrats in forum Video ConversionReplies: 202Last Post: 19th Jun 2012, 18:58 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 11:40 -
By nji899jus in forum Newbie / General discussionsReplies: 29Last Post: 15th Oct 2009, 09:32 -
How to Fit 3 movies on 1 DVD 4.7GB and keeping high resoultion and quality?
By Virius in forum Authoring (DVD)Replies: 4Last Post: 8th Aug 2009, 16:12 -
Encoding RM to AVI (high Quality)
By hzgg2 in forum Video ConversionReplies: 2Last Post: 22nd Apr 2008, 15:11
