Hello,
I have a DVD that has the subtitles as part of the video, like VHS tapes had. I would like to strip them off the movie and make a proper subtitle stream, that could be turned on or off, from them. The movie is a 4x3 letterbox and all the titles are in the lower black band. Can this be (easily) done?
If so, I would also like to convert the video to 16x9 anamorphic. I have used DVD-Rebuild to this with other discs, but they didn't have the problen with subtitles. The movie is very skinny and I would like to shift it up to the top of the screen, so there is room for the subs below in the black part.
Forgive me if this has been covered before. I couldn't find that it had.
Thank-you!
Cannot be done. I mean the subtitles bit.
He's a liar and a murderer, and I say that with all due respect. -
Theoretically is can be done, but it is not simple. There are subtitle programs that use Optical Character Recognition to try to 'read' subtitles from the video to convert them to text based subtitle formats. I haven'tplayed with these much, but the OCR seems to be pretty hit and miss, and not that accurate. That said, if the subs are only in the black you may have better luck. The only two listed in our tools section are avisubdetector, and subtitle workshop. The OCR function in Subtitle Workshop is experimental, and not very accurate.
Converting 4:3 to 16:9 is easy. Assuming NTSC because of your location, you need to remove a total of 120 lines from your image, then resizing it back to 480 lines. Usually this is done by simply taking 60 from the top and 60 from the bottom. In your case you may have to use 40 and 80, or 20 and 100. Avisynth is the simplest way to do this. If you can extract the subtitles, use 60/60. You may also have to mask the bottom of the screen to hide the subs.Read my blog here.
Originally Posted by dullard
Failing that, in principle it should be possible, when you have them on a black background, to convert them to a SUP file. But I don't know how it could be done in detail.
However, an alternative is to download a subtitle file from one of the many sites that offer these:
http://www.divxmovies.com/subtitles/
http://www.divxstation.com/subtitles.asp
etc.
These often vary in quality, some seem to be almost perfect, others have lots of OCR or translation errors.
Use Subtitle Workshop to edit and sync them with your video. You could leave the original ones there while you did this for reference and then crop them off as others have mentioned. -
("air" not "aire")
As mentioned, probably have to use a subtitle editor to sync them with your version.
Originally Posted by dullard -
They don't call me dullard for nothing!
Thanks, I'll try this out.
Blurring and overlapping hard subtitles
By jairovital in forum SubtitleReplies: 8Last Post: 26th Oct 2010, 18:37 -
How do I download YouTube captions and convert them into hard subtitles?
By Daniel_BMS in forum SubtitleReplies: 0Last Post: 1st Oct 2010, 17:33 -
How to extract Teletext substream from mpg ?
By Robertus in forum SubtitleReplies: 11Last Post: 27th Sep 2010, 09:49 -
How to blank out hard-burned subtitles
By Flasharino in forum EditingReplies: 2Last Post: 16th Jun 2009, 08:00 -
How to make subtitles HARD in DVD
By blue2 in forum Authoring (DVD)Replies: 4Last Post: 14th Mar 2009, 12:27
