I cannot properly capture sound as there is no sound
but a beat coming inside the audio card from the AIW
did anyone experienced a similar problem?
1st: Make sure you have your pass-thru cable plugged into "Line In" on the card, and select "Line In" under the Windows Recording volume control too.
2nd: Sound Blaster Live card... with what OS? Perhaps drivers are not correct?... -
Hey, I have the same problem. The thing is, you cannot just plug the SB Live into the ATI AIW, because the passthrough on the ATI AIW is a different connector than the one on the sound card. Right now I'm using the microphone jack and it sounds like ****. I'm gonna see if there's a special cable u can buy.
AMD ATHLON XP 1700+ CPU
ABIT KR7A-R MOTHERBOARD
512MB PC2100 RAM
SONY 21" TRINITRON CPD-G520 MONITOR
ATI ALL IN WONDER RADEON 8500DV 64MB NTSC
ENERMAX FS-710BB 330W FULL TOWER CASE
SONY SPRESSA 16X/10X/40X EIDE INTERNAL CDRW
C -
line out from the AIW is plugged into the line in
of the card. The fact is that at the beginning while
installing stuff it works, then (but cannot figure out what it is) while drivers are added.. the sound out of the aiw does not work.
Os is XP but did it also under Me
ATI support suck a big way also..they were never able to give me an answer as if my hardware was a outer space config
WDTV Live to Soundblaster Audigy 2?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 3Last Post: 12th Dec 2010, 00:25 -
How to broadcast a live satellite TV by Adobe Flash Media Live Encoder
By mrweb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Aug 2010, 21:08 -
Creative SB Soundblaster Live and Ubuntu 8.04
By Ogilvy in forum LinuxReplies: 6Last Post: 12th Jul 2010, 08:50 -
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 22:45 -
No soundblaster midi with x-fi extreme audio pci-e
By johns0 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 21:01
