helloi recently downloaded the SUPER video encoder and it's great! works very smoothly and well =) i had one very minor problem that maybe someone can help with. when i convert a video to almost any format, the sound lags behind just slightly, a fraction of a second but enough to know. i've tried all different settings to no avail. any suggestions? thanks
the videos i've converted are originally wmv format. the picture looks fine, just the sound barely out of sync.
I have had NOTHING but trouble converting wmv stuff. They always seem to go out of sync. The length is part of it. For short wmv files, 22 minutes of less, there is no problem, but longer files lose sync. The only ways I have discovered that work to prevent sync loss are one of the following:
1: Mediacoder. Mediacoder is a work in progress, and has lots of problems, but when it works, stuff stays in sync.
2: convertxto dvd.
3: Use Windows Movie Maker to convert to DV than use TMPGEnc or CCE Basic to encode to mpeg. -
In SUPER, the most common cause of sync loss is not selecting the same frame rate for the output video as the original video. (SUPER apparently doesn't attempt to guess or set it for you.) I don't know how well it works with WMVs, though.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
Audio Distortion with SUPER
By oller_a in forum Video ConversionReplies: 9Last Post: 24th Sep 2008, 14:21 -
trying to convert an Xvid avi to mp4 w/ SUPER. audio is out of sync!
By cduval04 in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 18:45 -
Help with Riva Encoder, or Super, HELP!
By atomic22 in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2007, 04:51
