I have been digging around for a while on this and cannot find an answer. Is it possible to insert an Exit Menu button in GFD? I saw an example using DVDAuthorGUI, but I don't see the same option available in GFD.
Thanks!
Brian
It's included in the new development version, but you can also do it manually. Just create a free Button and overwrite the action with 'exit;'
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
GUI for dvdauthor problems – Strange menu sequence behavior using Henc
By jsbullock in forum Authoring (DVD)Replies: 9Last Post: 20th Feb 2009, 02:44 -
GUI for dvdauthor Animated Menu Buttons
By deco81 in forum Authoring (DVD)Replies: 3Last Post: 6th Dec 2008, 18:41 -
GUI for DVDAuthor burning iso to dvd player no menu audio
By opti280 in forum Authoring (DVD)Replies: 13Last Post: 8th May 2008, 20:11 -
GUI for DVDAuthor Menu Problem
By jribeiro in forum Authoring (DVD)Replies: 3Last Post: 5th May 2008, 01:50 -
How to get PlayAll button working with GUI for DVDauthor ?
By micke65 in forum Authoring (DVD)Replies: 3Last Post: 5th Apr 2008, 04:00
