im facing the same problem. I have three avi files that i want to merge with virtualdub or nandub or any other tool. Problem is when I try to append the second file, i get an error saying 'Cannot merge. ....different audio sampling rates'. How can I fix this error so that the files can be merged?
You mentioned something about reencoding. How do I do that so that the audio sample rates are the same?
You could re-encode the audio to the same format and just use a common sampling rate for both files. You can do that in VirtualDub or use a audio editor. 48Khz is the DVD standard, probably a good rate to use. Use full processing in VD for the audio and Direct stream copy for the video. After you processed both videos you should be able to join them.
If you run into VBR audio, it can be a little more complicated.If the audio sample rates were different, someone may have already created some sync problems.
If your final destination is DVD, I wouldn't join them at all. That avoids some audio sync problems caused by bad joins. It works better to let your authoring program 'join' them when you author the DVD.
Alternately for all this, try ConvertXToDVD. It 'might' handle them as is. -
@shashgo: Please don't dig up year old threads - it's easy to start your own.
I've split this off for you.
/Mats -
Mats ,
I know that this is an old thread that I dug up. But I thought its better to do that than to start a new thread because another board said that i would halp conserve bandwidth by not starting new threads. But if its okay with you guys ill start new threads.
What should be specs of PC
By cyberlion in forum EditingReplies: 26Last Post: 6th Jul 2010, 07:50 -
Joining two AVIs in TMPGEnc Xpress
By jeanpave in forum Video ConversionReplies: 17Last Post: 8th May 2010, 23:16 -
? Shrinking Multiple AVIs to Target Total-Size Then Joining to Originals
By Synetech in forum EditingReplies: 2Last Post: 4th Apr 2008, 21:14 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 14:32 -
Trouble joining two mp4s (or two avis)
By nosillacast in forum EditingReplies: 2Last Post: 27th Sep 2007, 09:30
