I know that "Audio Delay" can be use to fix the synth problem in DVDLab Pro, since I don't know how many millisecond delay, it has to make many test and many compile with video in order for sound match. Is there anyway test how many millisecond in delay before compiling? or any other software other than DVDLab pro? Thanks
Media Player Classic allows you to adjust delay on the fly. Once you have the right number, use it in DLP. You find it under
Play -> Audio -> options, then tick Audio Time Shift and enter the offset. Click OK, watch, adjust until you get it right.Read my blog here.
DVDLAB+Runtime Error+Compile.aux
By icemanatvcd in forum Authoring (DVD)Replies: 6Last Post: 27th Mar 2014, 07:08 -
DVDlab Pro subtitle color wrong after compile
By nbarzgar in forum SubtitleReplies: 1Last Post: 9th Jun 2009, 10:29 -
Subtitle problem with DVDLab Pro
By carlmart in forum Authoring (DVD)Replies: 3Last Post: 21st Nov 2008, 10:18 -
DVDLab Pro 2 compile issues
By milofhead in forum Authoring (DVD)Replies: 3Last Post: 28th Oct 2008, 00:25 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
