Maybe SUPER (Freeware) will come to your rescue as it has others.
SUPER will convert to most formats that exist.
I didn't think tmg (Do you mean TMPGEnc) accepted the ASF format and WinAVI,well,I'd stay away from it.WinAVI is so buggy and you have to pay for it.
ASF should be installed anyway with WMP.~Luke~ -
Thanks,I'm glad you like my suggestion.
I like people like you who have respect and thank people for any ideas.
Some people dont bother thanking.
I'm not too sure of the quality SUPER gives when converting directly to DVD because I use it to convert from formats like ASF,WMV,RM ect... to AVI or AVI to them.
You could use it to convert the ASF to an AVI with the lossless HuffYUV codec and then use a quality MPEG-2 encoder and finally author.This should be a better way of doing it and everything should run smoothly.~Luke~
Best way to install popular codecs
By snafubaby in forum Newbie / General discussionsReplies: 20Last Post: 25th May 2011, 07:30 -
What codecs should I install? Which are the best?
By DonGallego28 in forum Newbie / General discussionsReplies: 29Last Post: 22nd Sep 2009, 13:23 -
Understanding Gspot and Codecs Redux
By neumannu47 in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 22:43 -
Does SimpleDivX install its own versions of codecs?
By Toastie in forum DVD RippingReplies: 0Last Post: 1st Sep 2007, 16:23 -
Codecs - Which to install on fresh OS?
By acommuter in forum Newbie / General discussionsReplies: 9Last Post: 7th Jul 2007, 17:39
