I've seen the guides here that show you how to do DV to XviD conversions, but they all refer to actual camcorder footage.
I have some letterboxed TV shows (Battlestar Galactica, etc) that are in DV format because I captured them with a Canopus ADVC-100.
I'd like to crop the black bars at the top and bottom, do an IVTC, and encode as 16x9 XviD.
Can someone fill me in on the best software for this, and the best way to do it?
Thanks...
I use VirtualDub Mod for that, but the regular VD will work as well. You need to add a DV codec. The Panasonic DV codec works for me. I'm not really knowledgeable about IVTC, but if your video is DV at 29.970, I'm not so sure you would need that. But others would know more on that. The cropping could be done in VD easy enough.
For 16:9 in the Xvid codec, 'Configure>Profile@Level>more>Aspect Ratio. But read the note there. Some players will ignore that flag.
I save out the audio as a WAV after editing, then use ffmpeggui to convert it to AC3 to add in later when authoring. I also frameserve the output of the VDM edit directly to TMPGEnc and encode only the video to MPEG-2. This saves hard drive space and time.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Xvid question, using MeGUI
By greyfalcon in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2010, 12:57 -
XviD playback question
By janlafata in forum Video ConversionReplies: 12Last Post: 22nd Dec 2008, 16:23 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 18:13 -
Iso to Xvid Question
By boing in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2007, 00:05
