i was hoping someone could help me or point me in the right direction ?
i have a MVCD mpg , i understand the problem with GOP to a certain extent , what i want to do is make this a normal mpeg so that i may use it with svcd2dvd .
i have sucessfully used it with other programs making them into a single DVD .
what i love about svcd2dvd is backing up my assetts in s2d.mpg format for duture use .
i want to use the a kvcd mpg becuase it is a small download and if i can figure out how to convert to a regular mpeg it may be a quicker conversion than divx to dvd.
anyway thats my reasoning and what i need help with ...
thanks in advance .
So what is the issue? Have you tried one of your files? If so can you attach your log file?
Its just like you posted here https://forum.videohelp.com/viewtopic.php?p=1225087&highlight=mvcd#1225087
it freezes (jitters) because of the GOP , ive found i can process it using nerovision and it works find but like i posted earlier i prefer SVCD2DVD (love your program) , if you can make it work with svcd2dvd , that would be awesome but if not , no worries .
svcd2dvdlog-20061024120152.txt
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
burning mvcd with Nero 8 Essentials or ???
By Jim S. in forum Newbie / General discussionsReplies: 3Last Post: 7th Apr 2008, 05:52 -
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 06:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08
