The manual indicates the software will support VIDEO_TS folder as an input.
http://www.ffmpegx.com/videots_divx.html
However in action it reports the following error.
"This engine does not currently support VIDEO_TS input. Use VOB input, or select a preset using mencoder or mpeg2enc engines."
Except creating a single VOB file are there any other tricks to make this work?
Does multiavchd or tsmuxer support .tp files as input sources?
By yoda313 in forum Video ConversionReplies: 8Last Post: 8th May 2010, 08:08 -
TMPGEnc Authoring Works 4 updated with WTV input support
By gyoshi in forum Latest Video NewsReplies: 0Last Post: 4th Mar 2010, 12:05 -
TMPGEnc MPEG Editor 3 updated with WTV input support
By gyoshi in forum Latest Video NewsReplies: 0Last Post: 3rd Mar 2010, 19:34 -
does procoder 3 support flv input for conversion?
By perfection in forum Video ConversionReplies: 2Last Post: 13th Sep 2008, 00:25 -
Capture card with Component (RGB) Input and 16:9 Support
By edt in forum Capturing and VCRReplies: 21Last Post: 27th Jun 2007, 09:58
