I have a question I wonder if anyone can help me with. I've got an old videotape I'd like to backup to DVD format. I capture the tape using Adobe Premiere Pro 1.5. However, when trying to convert the captured video to mpeg with TMPGenc, the program does not recognize the captured file as a valid avi.
The only way I can do it is to actually render the whole video in Premiere (which takes a long time) and then export the video to avi (which takes a long time) and only then convert to mpeg. Why is this, and is there any way to save the time it takes me to do this?
Output to dvd directly with premiere ?
What avi video format are you capturing to? dv-avi? then might you need a dv codec for tmpgenc like panasonic dv codec or frameserve directly from premiere pro to tmpgenc with debugmode frameserver. -
why don't you just choose "export timeline" and then "adobe media encoder" and choose "mpeg-2"?
what format is the tape?winxp - 3.06 -
Is there a way to capture directly to MPEG-2 on a Mac?
By pf4711 in forum MacReplies: 10Last Post: 24th Feb 2012, 18:15 -
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
Avi to MPEG-2 quality encoding mission
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2009, 01:10 -
Question - Capturing to MPEG directly with VHS cropping
By joejoe in forum Capturing and VCRReplies: 2Last Post: 24th May 2009, 22:45
