Hi -- I looked around in the forum and could not find an answer to these questions:
What exactly does Cinemacraft's (CCE) "Auto Intra DC Precision" setting do?
Am I better off selecting "10" for DV-to-DVD MPEG2 conversion, or better off
selecting "Auto"?
Thanks,
Kevin
It automatically selects a DC precision for you based on the set bitrate and the overal complexity of the source. It's not a bad idea to use it. No you should never select a DC value of 10 unless you use a very high bitrate, probably at least 7mbits. The CCE manual gives you a general rule to follow. I think its something like up to 4mbits you should use a DC of 8. Everything else should be 9 unless your bitrate is very high.
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 13:01 -
View intra DC precision
By Bergen in forum Video ConversionReplies: 1Last Post: 14th Aug 2009, 08:20 -
Auto-split 10 hr capture in 3 min chunks "on the fly"
By atvmxr in forum Capturing and VCRReplies: 2Last Post: 22nd Apr 2008, 09:48 -
"Samsung dvd r155" Auto time not working properly
By mace the ace in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Jan 2008, 23:54 -
"No adjustment is possible" error in Auto Gordian Knot
By rahul.never2far in forum Video ConversionReplies: 0Last Post: 20th Oct 2007, 08:40
