Hello i hope im not the only one with this problem. If having huge problems in Premiere when im exporting , when the movie is finished it is always alot of romm on all for sides of the movie which means that the whole screen is not used and then if therer is a transition or the speed is changed the the screen even comes smaller. Could someone help me thx
muffinmen.....
With all due respect...
Please post some information. Source files, Project settings, filters...
You don't even say what you're exporting to..
By the look of your computer details, it seems like you clicked the closest numbers to your fingers...
This is an advanced editor. Good luck!!! -
ok soory here are more informations i think this is my project settingt frame size 1280 h 720 v
Square pixels (1.0)
Progressive scane
30 fps Drop timecode
Hdv 720
Time base "29 .97 Frame per second"
but does settings i cant change.
So know i wont to export it as a mpeg or avi it doesnt matter the only thing matters that i can whatch it in good qualiti on my pc and without having half of the screen black on al four sides it would be good if its wiedscreen but what i have isnt widescreen its just black on al four sides and when an effect comes the screen even gets smaller please help -
no but does that mather? but then i started a nother project and i had the setings on dv and it doesnt work either please help me
it could be that it mathers does someone know if it mathers if you put in the wqrong settings in the begining is there away to change the settings
Major synchronizing problem please?
By tendra in forum Video ConversionReplies: 2Last Post: 31st Aug 2010, 11:28 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
Major 'Codec' Problem
By mattstan in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 15:18 -
Major Problem with AVI
By thepcpitstop in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Jul 2007, 11:49 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 08:30
