    Oct 2006
    Hi.
    I tried to make my dvd player region free with remote control codes i found here but it did not work.
    Instead the settings for pal/ntsc got changed The picture is black/white and rolling....
    Is there a way to fix this?? Maby there is a way to reset the dvd back to factory settings??
    Help please!!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    There is usually an option in the setup menu to control this option. There isn't another way of changing besides the menu.
    As many people here learn the hard way, using "hack" codes and flashing the firmware VOID the warranty. Perform at your own risk.
    Google is your Friend
