Hi,
I noticed that when I use DVD-lab Pro, it will identify a stream as "Dolby 1.0", "Dolby 5.1" or "Dolby 2/0", etc. However, it only does this if I extract the AC3 stream from a DVD and leave the file unaltered...
If I *do* alter the file, for whatever reason, and use BeSweet to create a new AC3, DVD-lab Pro doesn't identify it the same way. Sure, it'll say that it's 6 or however many channels (to be honest, I forget *exactly* what it displays), but it doesn't include the "Dolby" part...
How does DVD-lab Pro know that it isn't Dolby encoded, or, "official", if you will? Is there a header/tag included in AC3s that help identify them?
Also, does anyone know of some "official" Dolby encoding software? I shudder to think of the price, but I'm curious about what's out there.
Thanks again,
Justin
Certified Dolby encoding can be quite cheap, although it goes up with more channels. There is a certified Dolby encoder plugin for TDA for underUS$30, but it is 2.0 only. For 5.1 you need to look at either some of the prosumer editors (Vegas, Premiere) or the standalone encoders like Surcode. There are quite a few 5.1 encoding apps around if you google.
Read my blog here.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 19:49 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
