Okay i have 2 avi files that i want to convert to dvd. I go to add title and insert avi file #1, now from what i understand in the included guide it said something about joining 2 files within the same title to make play smoothly. I then go to edit title and add avi #2 and run the default settings. Now everthing seems like its going okay until playback of the final outcome. Now what happened is that avi file #1 and its audio track is straight no problems but where the second file should've picked up it didn't but the second file's audio and the first video is played again..so #1 vid & #1 audio and then #1 vid and #2audio..I can't figure out why the second video is not playin....????
http://www.dondivamag.com
:) This site is the Best thing since slice bread :) -
Too little info. What application(s) are you using for converting AVI to Video DVD? Following some particular guide?
/Mats -
im using the app "dvd flick" that's why I started the thread title, but i guess not many people use it, and its a all in one converter and author type program
Oh, that explains it. Try convertx2dvd (or the free predecessor DivX2dvd). Or read up on some of the numerous guides on AVI to DVD to be found under CONVERT left.
/Mats -
okay thanks
DVD Flick Problem
By alimustafakhan in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2011, 15:13 -
Problem with DVD FLICK while encoding
By hzgg2 in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2009, 14:39 -
Problem with DVD Flick
By Tbag in forum ComputerReplies: 4Last Post: 9th Jun 2008, 13:04 -
By Tbag in forum Authoring (DVD)Replies: 1Last Post: 8th Jun 2008, 12:32 -
Problem getting subtitles with DVD Flick
By rich1842 in forum Newbie / General discussionsReplies: 0Last Post: 10th May 2007, 12:06
