Hello everyone, hope you're all doing great.
My first time here, I'm a noob >_< and I hope someone will be able to help me.
So, I got a nice movie as an .avi file, tried playing it (using different players, but focusing on Windows Media Player v.9.0) and I can see some images but there are lots and lots of grey frames within its whole length. I used GSpot to try and identify the problem, it said the codec H264/x264 (ITU H.264) is not installed. So I found some codec pack - ffdshow, which was supposed to contain it and installed it. GSpot still says the codec is missing. The grey frames are still present.
I have no idea what to do at this point. I've been googling a lot but found no similar problems, maybe because I'm not a native english speaker and I couldn't be very exact![]()
As I mentioned, I'm not good at all at these things. Could anyone please suggest a solution?
Thank you,
best wishes,
Claire.
Another option may be to try the latest version of VLC Media Player. I use it to play H264's from the net. It's a freeware program and can usually play just about any format available, using it's own codecs, so no codec installs needed.
It's well worth having on your system, even if it doesn't work with this particular codec.
And welcome to our forums. -
Hello again! I've enabled the X264 decoding within the FFD, but that didn't help. Yet when using the VLC Media Player, everything was OK! I guess there might have been some other problems with my movie, but since it's now working just fine, I won't investigate any further.
Thank you, guys!
Best wishes,
Claire.
missing mp3 audio codec in ulead when saving as avi
By gabz in forum Video ConversionReplies: 3Last Post: 24th Jul 2011, 16:23 -
AVI jerky/missing frames?
By MdMa11 in forum Video ConversionReplies: 10Last Post: 25th Apr 2010, 23:13 -
missing frames
By carmatic in forum RestorationReplies: 11Last Post: 19th Feb 2009, 21:06 -
Gray shade in subtitles when [b]avi[/b] file is played in standalone player
By huRO in forum SubtitleReplies: 2Last Post: 1st May 2008, 14:15 -
converting videos to MP4/PS3 with SUPER - gray flashing frames
By xycer in forum Video ConversionReplies: 1Last Post: 8th May 2007, 18:47
