    Oct 2005
    Richmond, VA, USA
    Hello all! I thought I would be smart and figure out how to get HDDVD without having to buy a new DVD player. In my mind, I figured that if one could find an HD Divx file, then all you would have to do is burn that file onto a DVD (as a data disc, not as a DVD-video), slip it into the DivX upconverting DVD player (with 1080i output via HDMI), and watch true HD stream across your television. However, whenever I try to play the file on the DVD player, it simply says "Cannot play this file." No reason or anything. I am wondering if it has to do with the high resolution, but I am not exactly sure because I am no expert at this. Other DivX files (standard definition) that I have burned have worked on the player - why won't the HD one work?
    Here is the information for the file in GSpot:
    VIDEO
    Codec: DivX 5.0
    Length: 00:48:27
    Frames: 69,695
    kbps: 2433
    Qf: 0.110
    Pics/sec: 23.976
    FPS: 23.976
    Resolution: 1280x720
    FAR: 1.778 (16:9)
    PAR: 1.00
    DAR: 1.778 (16:9)
    AUDIO
    Codec: AC3, Dolby
    48000Hz
    448 kb/s total
    5 channels
    Is it possible that it won't play because it is a progressive image? Can anyone try to help me? Thanks in advance...
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    It won't play because none of the current divx players support HD files.
    Google is your Friend
    Some very few players supports hddivx, https://www.videohelp.com/dvdplayers?DVDname=&Search=Search&dvdportable=&dvdchanger=&dv...Submit2=Search
    But I would instead make a htpc...
