This afternoon I updated Democracy and iSquint. Since then I cannot play most of my .avi files.
ISquint and ffmpeg still can convert them but Quicktime, MPEG Streamclip and Toast all crash when trying to open these .avi files. Some of them I've had for years.
I've tried deleting Democracy and iSquint, reinstalling Quicktime and all of my divx codecs. Nothing works.
I have OS 10.3.9, the latest version of Quicktime 7 and Toast 7.
Any idea what the problem is?
Try using VLC Media Player. If it successfully decodes the videos, then you likely have a problem with your codecs. Does this only happen with Divx? Or do you have the same problem with other MPEG4 (AVI type) codecs.
If you have the proper Divx codecs, you might go to the Divx site and see if they have any simple answers.
If you go to this page, you might find some help under 'Top 20 Issues.......':
http://support.divx.com/cgi-bin/divx.cfg/php/enduser/cci/support.phph
Click on the apple for your product or look in the FAQs. -
Have you tried the normal OS X troubleshooting procedures, such as repairing permissions?
If cameras add ten pounds, why would people want to eat them? -
I have no problem using the VLC Media Player. I do seem to have the same problem with all types of .avi codecs
Have you checked the contents of /Library/QuickTime and ~/Library/QuickTime ?
QuickTime Player crashes
By anbarasan in forum Software PlayingReplies: 32Last Post: 12th Dec 2011, 08:22 -
Program crashes while opening
By creeper in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 3rd Aug 2009, 12:55 -
TMPGenc crashes when opening avi
By Kromgol in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 09:03 -
Uncompressd AVI Files Out of Sync in Quicktime
By phild in forum Video ConversionReplies: 2Last Post: 17th Aug 2008, 13:05 -
Quicktime crashes my computer
By tnerb33 in forum Software PlayingReplies: 4Last Post: 15th Jun 2008, 03:49
