Hey all!
Got some problems with my Nerovision.
When i want to burn a DVD it fails. I've tried 3 times in a row now and it keeps failing.
in error log it says:
[17:58:41] NeroVision 5:58:39 PM #22 CDR -1046 File ThreadedTransferInterface.cpp, Line 1614
[17:58:41] NeroVision Illegal disc
[17:58:41] NeroVision 5:58:39 PM #23 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1614
[17:58:41] NeroVision Could not perform start of Disc-at-once
[17:58:41] NeroVision 5:58:39 PM #24 Phase 38 File APIProgress.cpp, Line 273
[17:58:41] NeroVision Burn process failed at 2.4x (3,324 KB/s)
I dunno if there's something wrong with the discs I use....they r common DVD -R discs.
Anyone got any clues??
Cheers for now
[17:58:41] NeroVision 5:58:39 PM #22 CDR -1046 File ThreadedTransferInterface.cpp, Line 1614Read my blog here.
As guns1inger pointed out, they are either CDR's or you have a faulty burner.
Google is your Friend -
How old is your burner? The log says burning at 2.4X.... Are you trying to use for example 16X discs
The burner is 3 years old give or take (NEC DVD RW ND-2500A), and yes i'm trying to use 16x DVD -R discs. Is that the problem?
Yes. I have the same burner and hit the same problem recently using TDK 16x discs. I solved it with a firmware upgrade. I used the hacked 2.18 revision for the 2510A, which gives DL capabilities as well. Search for it on rpc1.org
Note : you wont get 16x burning out of these discs, but you will get 8x and they will be recognised. I have had it in for 2 months or so with no problems.Read my blog here.
Its reporting "bad media" ... take them back for exchange .
It happend to me using new tdk's (nolonger produced by tdk = rubbish)
Consider verbatim's ... esspecially when it come's to long term storage ... they out last most brand's .
SVCD2DVD and then burning with imgburn fails
By baby2003 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2010, 13:57 -
Burn fails while burning DVD video not data dvd
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 01:27 -
Burning always fails at 98%...
By Variable in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Feb 2008, 15:45 -
DVR 633 fails to initalize when burning to DVD
By Howardlan in forum DVD & Blu-ray RecordersReplies: 5Last Post: 11th Nov 2007, 17:46 -
Help Burning a disc fails at 1%
By DuBsTaR in forum Newbie / General discussionsReplies: 7Last Post: 7th Jun 2007, 17:16
