i have 12 eps of an anime (total = 4-5 h)that I want to encode to DVD ( authoured by Tmpgenc dvd author )
I set Mainconcept
output format :
MPEG type : dvd (program ((video + audio ) at 1850 (average bittrate) and 352-240 resolution (Scale 348 -208 to prevent overscan ) but Mainconcept give error " the parameter is incorrect "but if i set Resolution = 720 -480 then it works
Could someone please tell me how to make Mainconcept work at that resolution ? I searched in Google in hours but couldn't find anything to deal with it.I'm pulling my hair out
Any help would be very appreciated![]()
I'm sorry for my poor English
in a nutshell, you are trying to create a DVD compliant stream using a non-DVD compliant resolution, that's why main is scolding you.Originally Posted by winxp
if you want to create a DVD compliant stream, you need to encode to 352x240, 704x480, 720x480, 352x480 (if you're encoding NTSC compliant DVD's). -
I edited my post
My resolution is Width 352 - Height 240 (Scale 348 -208 to prevent overscan )
thanks
Any ideal ? Please
I'm sorry for my poor English -
I'll go crazy if I can't solve it ,It took me 3 days to search in the Internet .I'm totally get lost . Please help
I set 1850 CBR but it didn't work "the parameter is in corret "Originally Posted by guns1inger
I think problem is the resolution because if I set resolution = 720-480 it does work
But what I want is resolution = 352 -240
anyway ,thanks for your response
low resolution
By rosmari in forum RestorationReplies: 19Last Post: 22nd Apr 2010, 17:23 -
Like low resolution at traditional TV.
By newbievideohelp in forum Video Streaming DownloadingReplies: 13Last Post: 17th Oct 2009, 01:46 -
Video Captured Low in Quality/Resolution
By kakashi123 in forum Capturing and VCRReplies: 4Last Post: 10th Jul 2009, 18:36 -
Mainconcept MPEG-2 / H.264 refuse to encode interlaced footage
By Colmino in forum Video ConversionReplies: 0Last Post: 2nd Jul 2008, 15:23 -
Low framerate after BD encode
By h41cyon in forum Blu-ray RippingReplies: 3Last Post: 24th Mar 2008, 00:34
