Hi,
I'm trying to encode my short film to specifications that are recommended for putting vids on Google Video. I used Super to do it, because of all the specific options it gives you. My film is about 12 mins long, but every time I use it, it only seems to encode about 3 mins of the film. Any ideas whats the problem?
J
Assuming there is nothing wrong with SUPER, you may have a break in the file that stops the program. Depending on what format it is, try dropping it into Gspot 2.60 to see what it says. Post a screenshot here. If you need the method: https://forum.videohelp.com/viewtopic.php?t=271697 Blank out the title if you like.
When playing the original, does anything happen at the 3 minute mark with the video? If you think SUPER is the problem, uninstall and reinstall it. And try another encoder to see if it has the same problem. You may be able to open it in VirtualDub or VD Mod and check for errors, then resave it as a 'Direct stream copy'. This sometimes fixes indexing errors.
newbie having problems with SUPER ©
By emb36206 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Nov 2010, 05:04 -
Super C Problems - Recent Version
By PowerFalcon in forum Video ConversionReplies: 6Last Post: 18th Jun 2009, 19:04 -
Recently problems with Super converting Youtube files
By brassplyer in forum Video ConversionReplies: 1Last Post: 11th Jun 2009, 08:00 -
having problems with super ffe and avanti
By rugrat23 in forum Video ConversionReplies: 3Last Post: 4th Dec 2008, 11:36 -
SUPER converter problems (PSP)
By iThinkYouBrokeIt in forum Video ConversionReplies: 1Last Post: 24th May 2007, 18:57
