  1. Has anyone else experienced problems with using the batch process with version 2.50. I set it up last nite to encode 4 movies, had everything going, got up this morning for work at 5 am and the first file finished without any problems, then TMPGEnc just shut down and would not start the next file?? I had to manually start the next one to encode while i am at work. Is there a earlier version of TMPEGnc that the batch process works. I have been encoding for about 2 months now and this is the first time I have used the batch process.
    Another quick question, when I load the proper template, and check on the second tab Advanced under source aspect ratio, it always says 1:1 vga, I have gone and set each file up to encode for 4:3 525 line NTSC which is what i need to play on our TV ,will it make a differnce on playing back on my DVD player if this setting goes to 1:1 vga when encoding in the batch process.
    Thanks in advance on this topic.
  2. Dunno if your problem is related to the one i had, but i found mine would stop encoding whenever TMpegEnc was not the active application...id start enconding and it would say something like 3 hours lef tot encode, then when i came back 2 hours later it would tell me that it had 9 hours left and the program would respond sluggishly...i have founf that under Options->Task Priority that the When Not active task priorty was set to Idel Time only. changed it to normal and it fixed it....
