I've encoded some flash video for a website I'm doing. Had a friend in another state try to go to the website and play the video and he says he's only getting audio, no video.
His info:
Linux (SUSE 9.3 distribution, but with occasional upgrades that I do) 2.6.11.4 kernel build
Firefox: 1.5.0.1 (the Flash plugin is at version 7.0.63.0)
I don't know much of anything about Linux, but I'd like to know if Flash Video (.FLV) is supported for this operating system. He does have the Flash plugin for his browser as stated above.. I encoded using the On2 VP6 codec..
FLV4/5 are only supported since flash 8. You would need to encode with FLV1 (Sorenson Spark).
Not sure what flash version is available for linux since I run x86 64 and last I checked they don't have any version for that. -
thanks for the reply.. shortly after I posted, I found a pre-release/beta page for the flash player. Sure enough after getting that Beta, the video worked perfectly. Adobe, for whatever reason just hasn't released it yet.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
flv Audio/Video out of sync
By anmldr in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2010, 12:30 -
Capture Live Streams and Regular FLV with Linux?
By mkvbob in forum Video Streaming DownloadingReplies: 1Last Post: 9th Jan 2010, 22:10 -
Captured video/audio progressively out of sync (on linux)
By daytooner in forum Video Streaming DownloadingReplies: 2Last Post: 26th Nov 2009, 00:26 -
(linux) Problem downloading flv file [solved]
By aboa in forum LinuxReplies: 2Last Post: 25th Mar 2009, 13:56
