For divx/xvid files?
How do you play them and what files do they support?
Thx
You can set it to autodetect subs in 'Preferences'. Click the 'Advanced Options' then 'Video>Subtitles/OSD'. You should see a bunch of subtitle adjustments. You can also point it to a subtitle file.
For some subs, you start the program, then use 'File>Open File'. This will give you a window to browse to the video and also the subs. Then hit 'OK'. The sub doesn't have to be in the same place as the video. There are also some advanced sub settings there, like size.
I'm not sure what all formats of subs it detects and plays, but .srt subs work. Here's a link to the features page: http://www.videolan.org/vlc/features.html
Please Support Lunettes Branch Of VLC For Mac
By VideoNoobz in forum MacReplies: 0Last Post: 6th Apr 2010, 18:20 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
Unicode support in VLC?
By kitabata in forum Software PlayingReplies: 2Last Post: 20th May 2009, 04:19 -
Media Player Classic Laggs, VLC didn't support ASS sub
By greator in forum Software PlayingReplies: 1Last Post: 24th Nov 2008, 06:40 -
seperate subs not optional on vlc playback
By marinebc11 in forum MacReplies: 5Last Post: 29th Aug 2007, 03:30
