I usually capture my home movies from analog tape into a 2 hour long MPG2 file.
I alway use the Fade In/Out feature on these movies between scenes.
I'd like to find a way to automatically split the MPG2 file into the separate scenes and have each scene put into an individual file. This would allow me to trim a 2 hour movie down to something much shorter using the editing software I use (Ulead DVD MovieFactory 3). By having each scene in a separate file I will only be putting the desired scenes on the DVD and nothing else.
Does anyone have any suggestions? I've been doing this by hand with TMPGEnc, but that is tedious.
thanks,
Kevin
Results 1 to 1 of 1
Automatically cropping 4:3 to 16:9
By RockVideoDude in forum Newbie / General discussionsReplies: 6Last Post: 29th Sep 2011, 21:47 -
want wmp to open automatically
By chris_j11 in forum ComputerReplies: 2Last Post: 1st Aug 2008, 18:14 -
How does vobsub automatically start?
By subsync in forum Video ConversionReplies: 5Last Post: 10th Dec 2007, 13:21 -
Looking For A Cropping/Splitting/Converting Tool that supports MPEG2
By LordOfTheStrings in forum EditingReplies: 21Last Post: 12th Nov 2007, 12:09 -
Touchpad automatically turns off?
By jyeh74 in forum ComputerReplies: 2Last Post: 20th Oct 2007, 13:38
