I got a ton (literally) of VCDs that I would like to convert to DVDs so I can drastically decrease the amount of discs I have.
Im using Roxio9 to convert my .avi's to dvd.
How would I go about ripping a VCD onto the computer and then burning those files into DVDs?
VCD video resolution is supported in DVD, the audio need to resampled. About 6 VCDs can be packed into a DVDR.
The easiest approach is to to rip out the mpeg file from each VCD, and then use TMPGenc DVDauthor to put multiple of them on a DVD. Note : TDA will re-sampled the audio. -
wow, thanks a lot guys!
This has to be one of the most useful, helpful and friendly forum on the web.
Dvd Format Questions
By Winsordawson in forum Newbie / General discussionsReplies: 33Last Post: 29th Aug 2010, 02:34 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
DVD to storage drive, best media player for dvd playback- newbie questions
By omkls08 in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2009, 11:22 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
HD DVD questions
By kinglerch in forum Authoring (DVD)Replies: 7Last Post: 5th Feb 2008, 16:15
