I am converting 640 x 480 avi file to 352 x 240 mpeg1 using Tmpgenc Plus. I did a batch encode and on all of the outputs, the sound dies at about 6 seconds into the video.
Any idea what might have gone wrong?
Results 1 to 10 of 10
Well i tried making different clips of 720x480, 704x480, 352x240 and they all lost audio at the same point of the video.
the audio is layer-2 48hz 192kbp (Im not sure if this answers the question of what type of audio. Im not sure where to find that)
the encoder I used was Tmpgenc Plus 2.5 -
Is there any other software I can use to just convert the avi to mpeg with freedom to change output resolution. The avi is already 48hz so I dont need to change it.
MP3 doesn't mean much. It's the details about it that could. Is it CBR or VBR ?
tmpgenc is a good encoder. More than adequate for VCD encoding, which is effectively what you are doing.
Personally, I would use virtualdubmod to save an uncompressed wav version of the audio track, and convert this to AC3 seperately (i prefer it to mp2 for compatability), then bring the two together during authoring.Read my blog here.
hmm i think i have virtualdub installed.
So what I do is extract a .wav file from each of the source avi and use that as audio source during the authoring correct?
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 21:20 -
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 23:34 -
Help: losing audio on TV going from HD to SD content
By scarecroe in forum DVB / IPTVReplies: 2Last Post: 26th May 2010, 16:29 -
losing audio help
By tim37 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2009, 22:45 -
Converting .WMV to .MPG and losing audio/picture
By frenchdb in forum Video ConversionReplies: 1Last Post: 29th Jun 2008, 21:42
