I have a mitsubishi 52" 1080p DLP(WD52627) tv. I was looking into getting an upconverting dvd player, and contacted OPPO about one of theirs, I got a response saying that with DLP tvs, there may need to be a significant calibiration for the dbd player to work properly (jaggies, blockiness).
My question is has anyone with a 52"+ DLP experience any of these problems or others?
What upconverting dvd players have you used ona 52"+ DLP
What We Do In Life, Echoes In Eternity....
Hi-
All Hi-Def displays should be calibrated to the player. Nothing peculiar about the Oppo in that regard. At the very least run the TV through the THX Optimizer found on all the Star Wars DVDs, as well as on hundreds of others, after you get your new player. The macroblock enhance problem, for DLPs especially, can be a serious one without a proper calibration, if the player has a Faroudja chipset (Oppo).
If you're planning on getting an Oppo (highly recommended), I'd wait for the 1080p model due out shortly, the Oppo DV-981HD . The current models upconvert only to 1080i and 720p. -
Ok, so all I would really need to do is use the THX optimizer (which I have already done for my current dvd player with the OPO (or whihc ever I buy) and it should work fine?
What We Do In Life, Echoes In Eternity.... -
Yes, should work fine. You don't optimize the Oppo, though. The default settings are pretty much right on. You adjust the settings in the TV set. I may have misunderstood what you were saying.
analog upconverting
By jaybird in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2010, 21:20 -
HD and upconverting over component?
By RoyGBiv-inRI in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Jul 2009, 19:40 -
Anyone see "The Dark Knight" in a Theatre with DLP?
By peggypwr1 in forum Newbie / General discussionsReplies: 3Last Post: 30th Jul 2008, 23:45 -
When upconverting doesn't
By Seeker47 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Feb 2008, 13:34 -
Still confused on upconverting
By glp103 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jan 2008, 16:42
