I'm using a Pinnacle 500 USB capture card, and in trying to capture in programs besides Pinnacle Studio 10 (which was uninstalled because it was making the computer slow) I don't pick up audio.
Can anyone give me a solution to this?
are you trying to capture with Pinnacle Studio 10 and u get no audio?
To properly capture with a USB capture device you generally speaking have to use the included software because the hardware is usually proprierity so other software doesn't work.
This is not the case with all USB capture devices but generally speaking it applies to most.
So in short you are better off looking at ways to get the Pinnacle software working correctly rather than looking at other software.
John,
there is a difference if is PCI or USB device about the software?
I tried my Pinnacle PCI with Studio 8 and yesterday with Ulead Media Studio 8.0, I can't see difference about capture stuff with it.
Just my opinion
It is a bit different with USB devices as they tend to have proprierity software.Originally Posted by Sepu
There are some choices that may or may not work such as (in no particular order):
1.) GB-PVR
2.) MythTV
3.) BeyondTV
4.) ChrisTV
5.) SageTV
6.) TitanTV
There are probably more but those are the most popular as I know it.
I looked at each one and while some had Pinnacle products listed not one of them specifically listed the Pinnacle Studio 500 (neither PCI nor USB versions).
well i've had many bad experiences with the Pinnacle software, so would like to edge away from there to other third party programs.
OFF TOPIC: Where do you live in pittsburgh PA? I'm in the south hills -
BrooklineOriginally Posted by Dem Pyros"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
USB 500 capture
By kortmann in forum Capturing and VCRReplies: 2Last Post: 18th Sep 2010, 18:44 -
Pinnacle 500 USB
By Dem Pyros in forum Capturing and VCRReplies: 20Last Post: 26th Aug 2010, 12:18 -
Pinnacle usb 500
By kortmann in forum Capturing and VCRReplies: 2Last Post: 25th Aug 2010, 23:50 -
Is There Such A Thing??? re: Pinnacle Studio 500 USB
By drtalk in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2010, 19:21 -
Pinnacle 500-USB?
By beene in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2008, 03:13
