Does anyone know if there is a way to remove Nero Showtime by itself? It's taken precedent of all my video file types that I wanted Media Player Classes to play. Also, all my video icons are showtime icons. Please help if you can.
To remove Nero ShowTime, I believe you have to completely remove Nero 7.
To fix your problem, do the following:
Go to one of the files you want to open with Media Player.
Right click on the file.
Move Down to 'Open With' then select 'Choose Program'.
Go through the list of available programs and click on the player of your choice.
Check ' Always use the selected program to open this kind of file'.
Click 'OK'.
The file should now open with the player you chose and all the icons on your computer for that file type should now be for the player you chose.
Anthony -
need help
have installed Nero 7 and my dvd files are associated
with Nero Showtime.
I tried right clicking and open with, but it doesn't change them
It did change avi to windows media player though.
i am just really confused ~ should i just uninstall nero 7 and
start over again
thanks in advance for any help -
What jonas said, is true, that is the only way to change the file associations. If you had Total Commander instead of only Windows Explorer there would be another way.
www.ghisler.ch for that one.Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
Nero Showtime plays m2ts files
By wulf109 in forum Software PlayingReplies: 0Last Post: 10th Nov 2008, 21:30 -
Can't read Dvd, just with Nero Showtime
By sunco in forum Newbie / General discussionsReplies: 6Last Post: 17th Sep 2008, 01:31 -
Nero Showtime 4 Freezes When Capturing A Frame
By sbpyper in forum Capturing and VCRReplies: 0Last Post: 10th Jul 2008, 05:56 -
How do I install Nero Showtime and only that?
By fk in forum Software PlayingReplies: 0Last Post: 16th Apr 2008, 04:17 -
DVD has no sound in WMP, but does in Nero Showtime
By tom.s in forum DVD RippingReplies: 1Last Post: 14th Aug 2007, 16:44
