Help on this would be really appreciated. I'm a total newbie and have got a Panasonic NVDS27 DV Camcorder.
I've installed a Dazzle Firewire card and tried to capture Video but its jerky when I play it back. Is this "dropped frames" ? I'm playing it back with Microsoft Media player, and have installed DirectX 8.0 and the Microsoft DV plug in.
I capture using the bundled software from Ulead, DV-Editor Video Studio 4.0
My system is Windows ME, P3 1Ghz, 256Mb RAM, 40Gb Seagate 5400HDD, 40Gb Western Digital 5400 HDD (For Vidoe capture), Soundblaster Live S/c, Internal SCSI card for External Yamaha 4416SX CDR.
Anyone tell me where I'm going wrong ? Do I need a faster HDD or a SCSI HDD, Is my Ulead software crap ? Do I need XP ?
Please help, dazed and confused !!!
If it's anything it's probably your HDD. for capture 7200rpm is suggested.
Besides the need for a 7200 rpm hd, have you enabled DMA addressing for you HD in system properties? It can double your HD speed
Probably capture to the HD that is using different IDE port (IDE cable) from your C-Drive (most likely secondary IDE port).
Stop as many non-essential background process as you can.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
WinDV dropping frames
By 2Bdecided in forum Capturing and VCRReplies: 3Last Post: 17th Oct 2009, 03:23 -
Dropping frames while converting to .dv
By Huntr777 in forum MacReplies: 1Last Post: 10th Jun 2009, 16:19 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 15:06
