My computer plays original vcds just fine, but does anyone know if it can play backups? someone sent me a copy of a movie and they don't play on neither media player or on my dvd player
<font size=-1>[ This Message was edited by: etong on 2001-07-19 13:55:36 ]</font>
the thing is, do those ahem "backups" work on your friends computer?
if they dont work they were prolly burnt wrong try going to the tutorials that show you how to make copys i mean "backups" of the vcd's
hope that helps -
yea but i was just trying to find out if you can always play cdr copy on a computer, i understand not all dvd players play them, so does that rule apply to computers also?
nah man well hmm if you have a verry slow assed computer.
but im guessing you dont.
but you said normal VCD's can play easily on your comp rite?
well the thing with home players some of them can only play "printed" vcd's that means the information is like stamped on instead of burned.
but i dont see the problem with pc unless you have a screwed up burnd VCD. or you have a verry old cdrom.
or maybe a missing *.dll file (thats a diff story)
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 05:35 -
Is there any free VCD playing software which meets my requirement?
By csh in forum Software PlayingReplies: 11Last Post: 20th Dec 2007, 01:21 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25
